Catalindci
Localitate: Pitesti
Probleme punere contact, erori multiple
18 Oct 2018, 12:01
Salutare,
Revin si eu cu o intrebare dupa ce am trecut de la 1M, 1P, 1P1 la 5F, am o problema destul de ciudata cu masina, si anume cand pun contactul aleatoriu, chiar si la cateva zile, sau zilnic mai nou) ei bine se face pom de craciun si nu mai functioneaza nimic ( toti martorii raman aprinsi, nu merge servo, nu merge vitezometru, nu merge lane asist, etc)
Am fost la reprezentanta, m-au pus sa schimb bateria, am schimbat 2, problema persista, am cumparat VARTA AGM noua,nu prea stiu ce sa ii mai fac.va las in atas scanarea cu vcds, poate s-a mai confruntat cineva cu beleaua asta si ma scapa si pe mine de problema.
Masina in cauza: Leon 5F, FR, 2.0TDI 184 cai, manual, 2014
Am folosit VCDS 18.2 (Clona)
Multumesc
"Thursday,18,October,2018,12:32:48:00006
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64
VCDS Version: 18.2.0.3 (x64)
Data version: 20180212 DS287.0
http://www.Ross-Tech.com
VIN: VSSZZZ5FZER06 License Plate:--
Mileage: 184593 km Repair Order:
Chassis Type: 5F-SE37 (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 55 5F A5 A9
VIN: VSSZZZ5FZER06 Mileage: 184593km-115370miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: Malfunction 0010
5F-Information Electr. -- Status: Malfunction 0010
A5-Frt Sens. Drv. Assist -- Status: Malfunction 0010
A9-Struct. Borne Sound -- Status: Malfunction 0010
Address 01: Engine (J623-CUPA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 EL HW: 04L 907 309 D
Component: R4 2,0L EDC H22 6556
Revision: 83H22---
Coding: 01190012042401080000
Shop #: WSC 00049 770 00186
ASAM Dataset: EV_ECM20TDI01104L906021EL 002007
ROD: EV_ECM20TDI01104L906021EL_SK37.rod
VCID: 73E569CEDAB52EDC15-8026
1 Fault Found:
4713 - No Communication with ABS Brake Control Module
U0121 00 [032] - -
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 184593 km
Date: 2018.10.18
Time: 11:59:16
Engine speed: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 53 °C
Intake air temperature: 46 °C
Ambient air pressure: 980 mbar
Voltage terminal 30: 12.620 V
Unlearning counter according OBD: 40
Limitation: accelerator pedal: 126.7 Nm
CAN status - engine control module-Bits 0-7: 0
Cruise Control System (CCS): status-Bits 0-7: 6
CAN status - transmission control module-Bits 0-7: 0
CAN status - brake control module 1-Bits 0-7: 0
CAN status - brake control module 2-Bits 0-7: 0
selected gear-Bits 0-7: 0
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104) Labels:. 5Q0-907-379-ESP-V1.clb
Part No SW: 5Q0 907 379 R HW: 5Q0 907 379 F
Component: EMB8 EHCB H31 0356
Revision: 00000000 Serial number: 63193000000328
Coding: 20EE629234260970007A060441C52904462C9000608294F400610070C003
Shop #: WSC 00049 770 00102
ASAM Dataset: EV_Brake1UDSContiMK100ESP 033001
ROD: EV_Brake1UDSContiMK100ESP_033.rod
VCID: 4B95D12EE2C5161CBD-801E
No fault code found.
Address 08: Auto HVAC (J255) Labels:| 5G0-907-044.clb
Part No SW: 5F0 907 044 E HW: 5F0 907 044 E
Component: Climatronic H03 0705
Revision: 00001K07
Coding: 00000114200100011105000000101000
ASAM Dataset: EV_ACClimaBHBVW37X 003017
ROD: EV_ACClimaBHBVW37X_003_SK37.rod
VCID: 285F4EA253F31D0470-807C
Fresh Air Blower Front:
Refrigerant Pressure And Temperature Sender:
Air quality sensor:
1 Fault Found:
459012 - Databus
U1121 00 [008] - Missing Message
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 218
Mileage: 184493 km
Date: 2018.10.16
Time: 13:45:00
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 AE HW: 5Q0 937 084 AE
Component: BCM MQBAB H H16 0124
Serial number: 00011331501963
Coding: 08100B46C24102FB4BE44080401C07281000000000000000000000000000
ASAM Dataset: EV_BCMCONTI 012001
ROD: EV_BCMBOSCH_012.rod
VCID: 7BF541EEF2E5669C4D-802E
Control Unit For Wiper Motor:
Subsystem 1 - Part No SW: 5F1 955 119 HW: 5F1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 131109 041 0574
Serial number: 131111174221
Coding: 0BC5FD
Rain Light Recognition Sensor:
Subsystem 2 - Part No SW: 5Q0 955 547 HW: 5Q0 955 547 Labels: 5Q0-955-547.CLB
Component: RLFS 024 0042
Serial number: Y13M10D29H15M11S37S6
Coding: 00885D
Sun Roof:
Subsystem 3 - Part No SW: 6R0 959 591 B HW: 6R0 959 591 B
Component: J245 PS72.023 H02 0007
Serial number: WOO25325742
Coding: 180102
1 Fault Found:
204546 - Remote key 2
B147A 18 [009] - Current Too Low
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 179
Mileage: 184493 km
Date: 2018.10.16
Time: 16:38:50
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-294.clb
Part No SW: 5Q0 919 294 C HW: 5Q0 919 294 A
Component: PARKHILFE 8K H02 0033
Revision: -------- Serial number: 94231332701824
Coding: 0031051001
Shop #: WSC 46611 001 1048576
ASAM Dataset: EV_EPHVA18AU3700000 002019
ROD: EV_EPHVA18AU3700000_002_AU37.rod
VCID: 3B7581EEB265A69C0D-806E
2 Faults Found:
12656913 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 183
Mileage: 184593 km
Date: 2018.10.18
Time: 11:59:17
12656920 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 183
Mileage: 184593 km
Date: 2018.10.18
Time: 11:59:17
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 3Q0 959 655 AB HW: 3Q0 959 655 AB
Component: Airbag VW20 011 0189
Revision: -------- Serial number: 003P3PM9BP0.
Coding: 98FCC000000000005C0000CC000800000065
ASAM Dataset: EV_AirbaVW20TS6VW48X 001116
ROD: EV_AirbaVW20TS6VW48X.rod
VCID: 7EF348FAE1F773B46A-802A
Side Sensor Driver Front:
Subsystem 1 - Part No SW: ----------- HW: 454 001 211 13
Component: SideSensor_Df 008 0887
Serial number: 3576U00000027CD05E0I
Coding: 2D2D2D
Side Sensor Passenger Front:
Subsystem 2 - Part No SW: ----------- HW: 454 001 111 13
Component: SideSensor_Pf 008 0887
Serial number: 3586U000000C657CED0Z
Coding: 2D2D2D
Side Sensor Driver Rear:
Subsystem 3 - Part No SW: ----------- HW: 454 801 111 13
Component: SideSensor_Dr 111 0148
Serial number: 3516R3CC943020000001
Coding: 2D2D2D
Side Sensor Passenger Rear:
Subsystem 4 - Part No SW: ----------- HW: 454 801 511 13
Component: SideSensor_Pr 111 0148
Serial number: 3526R87AF55020000009
Coding: 2D2D2D
Front Sensor Driver:
Subsystem 5 - Part No SW: ----------- HW: 454 802 710 13
Component: FrontSensor_D 114 0149
Serial number: 3556V35301C02000000X
Coding: 2D2D2D
6 Faults Found:
1049088 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 223
Mileage: 184490 km
Date: 2018.10.16
Time: 13:44:58
1052416 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 223
Mileage: 184490 km
Date: 2018.10.16
Time: 13:44:58
1052672 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 223
Mileage: 184490 km
Date: 2018.10.16
Time: 13:44:58
1052928 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 223
Mileage: 184490km
Date: 2018.10.16
Time: 13:44:58
1053184 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 223
Mileage: 184490 km
Date: 2018.10.16
Time: 13:44:58
1055232 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 223
Mileage: 184490 km
Date: 2018.10.16
Time: 13:44:58
Address 16: Steering wheel (J527) Labels:| 5Q0-953-549.clb
Part No SW: 5Q0 953 507 DK HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 31101308490897
Coding: 2C00
ASAM Dataset: EV_SMLSKLOMQB 017001
ROD: EV_SMLSKLOMQB_013_AU37.rod
VCID: 020B3C0A950F17540E-8056
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 5F0 920 871 A HW: 5F0 920 871 A
Component: KOMBI 303 2210
Coding: 07AD01006980000800086A02000000
ASAM Dataset: EV_DashBoardVDDMQBAB 008031
ROD: EV_DashBoardVDDMQBAB_008_VW26.rod
VCID: 275D4D9E5EED127C79-8072
3 Faults Found:
16776968 - Databus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 223
Mileage: 184490 km
Date: 2018.10.16
Time: 13:44:57
16776973 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 218
Mileage: 184490 km
Date: 2018.10.16
Time: 13:45:01
16776993 - Databus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 223
Mileage: 184490 km
Date: 2018.10.16
Time: 13:44:57
Address 19: CAN Gateway (J533) Labels:| 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 Q HW: 5Q0 907 530 F
Component: GW MQB High 125 1164
Revision: -------- Serial number: 0001335149
Coding: 030100F40B087300EF0006E8080F00010001000000000000000000000000
ASAM Dataset: EV_GatewLear 010015
ROD: EV_GatewLear_010_SE37.rod
VCID: 3F8DF5FEA67DBABC21-806A
Alternator:
Multi Function Steering Wheel Control Module:
Subsystem 2 - Part No SW: 5F0 959 537 B HW: 5F0 959 537 B
Component: E221__MFL-PR6 H03 0120
Serial number: 000000000A0142101013
Coding: 002000
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 5Q0 915 181 E HW: 5Q0 915 181 E
Component: J367-BDMHella H03 8043
Serial number: 4777161803
1 Fault Found:
131603 - No Communication with ABS Brake Control Module
U0121 00 [008] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 223
Mileage: 184490 km
Date: 2018.10.16
Time: 13:44:58
Supply voltage: Terminal 30: 12.5 V
Terminal 15: On
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
Part No SW: 5Q4 959 593 B HW: 5Q4 959 593 B
Component: TSG FS 009 0014
Serial number: 0000083496732
Coding: 00100320DE00040000001000
ASAM Dataset: EV_DCUDriveSideEWMAXCONT 006001
ROD: EV_DCUDriveSideEWMAXCONT.rod
VCID: 4487FA12CF9BD9647C-8010
Drivers Door Rear Control Module:
Subsystem 1 - Part No SW: 5Q0 959 811 A HW: 5Q0 959 811 A Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_DRV 005 0005
Serial number: 00000000000001132556
Coding: 310000
Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
Part No SW: 5Q0 909 144 L HW: 5Q0 909 144 M
Component: EPS_MQB_ZFLS 127 1021
Coding: 91
ASAM Dataset: EV_SteerAssisMQB 008022
ROD: EV_SteerAssisMQB_008.rod
VCID: 3D718FF6AC71A8AC33-8068
Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
Part No SW: 5Q4 959 592 B HW: 5Q4 959 592 B
Component: TSG BFS 009 0014
Serial number: 0000082738615
ASAM Dataset: EV_DCUPasseSideEWMAXCONT 006001
ROD: EV_DCUPasseSideEWMAXCONT.rod
VCID: 4385F90ECA95DE5C45-8016
Passengers Rear Door Control Module:
Subsystem 1 - Part No SW: 5Q0 959 812 A HW: 5Q0 959 812 A Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_PSG 005 0005
Serial number: 00000000000001109474
Coding: 290000
Address 55: Headlight Range (J431) Labels:| 5Q0-907-357.clb
Part No SW: 5Q0 907 357 HW: 6R0 907 357 A
Component: LWR-ECU 005 0080
Revision: -------- Serial number: --------------
Coding: 049A000009000000
ASAM Dataset: EV_HeadlRegulVWLWRMQB 001110
ROD: EV_HeadlRegulVWLWRMQB.rod
VCID: 75E157D6D4C130EC3B-8020
1 Fault Found:
13705472 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 218
Mileage: 184490 km
Date: 2018.10.16
Time: 13:44:59
Address 5F: Information Electr. (J794) Labels:* Redir Fail!
Part No SW: 5F0 035 846 A HW: 5F0 035 846 A
Component: MU-S-N-ER 040 0425
Serial number: E1F02111131740
Coding: 04730001FF0A000021110001000800002F0101040100010046
ASAM Dataset: EV_MUStd6C3PASE 002029
ROD: EV_MUStd6C3PASE.rod
VCID: 2643409A59E70B7442-8072
Operating And Display Unit 1:
Subsystem 1 - Part No SW: 5F0 919 603 A HW: 5F0 919 603 A
Component: ABTmin_Std_Nv H51 0022
Serial number: SEZ8Z9NL400H0W
2 Faults Found:
6702 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 218
Mileage: 184490 km
Date: 2018.10.16
Time: 13:44:58
Voltage terminal 30: 12.6 V
Network diagnosis-Status: Enabled
7206 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 218
Mileage: 184490 km
Date: 2018.10.16
Time: 13:45:02
Voltage terminal 30: 12.5 V
BAP-BAP_Function_ID: 02
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 5Q0-980-653.clb
Part No SW: 5Q0 980 653 E HW: 5Q0 980 653
Component: MQB_MFK H05 0051
Serial number: 10000004151
Coding: 0101010001000004000500000000000100
ASAM Dataset: EV_MFKBoschAU370 001001
ROD: EV_MFKBoschAU370.rod
VCID: 3A7B84EABD5F9F9416-806E
1 Fault Found:
524288 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 218
Mileage: 184490 km
Date: 2018.10.16
Time: 13:44:59
Control Module temperature: 31 °C
Outside air temperature: 19.5 °C
Vehicle speed: 0.00 km/h
Voltage terminal 15: 12.5 V
Terminal 15 on: 3.5 s
Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
Part No SW: 5F0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0001
Serial number: 131008200117
ASAM Dataset: EV_SoundActuaGen2AU64X 003010
ROD: EV_SoundActuaGen2AU64X.rod
VCID: 6ADB74AA8D7FEF14A6-803E
1 Fault Found:
0014 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Mileage: 184490 km
Date: 2018.10.16
Time: 13:44:58
End-------------------------(Elapsed Time: 03:30)--------------------------
Ex. Seat Leon 1.9 TDI ASV 2001.
Ex. Skoda Fabia 1.4 16V BBY 2003
Ex. Seat Leon Cupra 1P TFSI Candy White Stage 2+ 2008
Ex. Seat Leon FR 1P1 DSG TDI 170 2011
Seat Leon FR 5F 2.0 TDI 184 2014
Renault Megane III 1.5 dCi 90 2012
Opel Corsa D 1.2 80 2009
Catalindci
Localitate: Pitesti
Re: Probleme punere contact, erori multiple
17 Apr 2019, 14:25
Nimeni nimic?
Chiar si dupa ce am schimbat bateria (600 lei Varta AGM), problema inca este prezenta, eroarea apare la un interval destul de rar 2-3 saptamani, aceasi eroare.
Inaintea de schimbarea baterieri masina lua eroarea si de 4-5 ori pe zi.
La reprezentanta ridica din umeri...
Eu banuiesc pompa de ABS.
Poatre ma ajuta cineva.
Mersi!
