olirad
rog informatii
09 Dec 2012, 17:07
salut ,
am o problema , poate ma ajuta cineva .
am un SEAT TOLEDO 2005 , 1968tdi , dispare antigelul constant de cateva luni , fara a avea alte simptome
am facut un test , daca ma poate ajuta cineva cu citirea lui ...
Tuesday,01,March,2011,14:42:07:10074
VCDS Version: Beta 11.2.0 (x64)
Data version: 20110207
Chassis Type: 1K0
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 76
VIN: VSSZZZ5PZ5R054193 Mileage: 125030km/77690miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 016 HM HW: 028 101 195 0
Component: R4 2,0L EDC G000AG 7000
Revision: 12345678 Serial number: SEZ7Z0D2781374
Coding: 0050078
Shop #: WSC 80553 264 08679
VCID: 75E5E5E76701
1 Fault Found:
18104 - Powertrain Data Bus: Implausible Message from Steering Column Controller
P1696 - 000 - - - Intermittent
Freeze Frame:
RPM: 0 /min
Torque: 56.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.39 V
Bin. Bits: 00101100
Bin. Bits: 11000000
(no units): 4.0
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 041 HW: 02E 927 770 AD
Component: GSG DSG 041 0814
Revision: 03904010 Serial number: 00000410160148
Coding: 0000020
Shop #: WSC 06402 785 00200
VCID: CFA9F70F251D
No fault code found.
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0104
Coding: 0023282
VCID: 3A7F36DB0E9F
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 5P0 907 044 B
Component: ClimatronicPQ35 005 0202
Shop #: WSC 00000 000 00000
VCID: 2F69178FC5DD
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 1K0 937 049 N HW: 1K0 937 049 N*
Component: Bordnetz-SG H34 0803
Revision: 00H34000 Serial number: 00000001333573
Coding: 81880F2700041000001E00000100000000007F0B5C
VCID: 3A7F36DB0E9F
Subsystem 1 - Part No: 5P0 955 119 A
Component: Wischer SE359 012 0402
Coding: 00056272
Shop #: WSC 80553
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 C HW: 1K0 909 605 C
Component: S3 AIRBAG VW8 013 2100
Revision: 02013000 Serial number: 0033HD014Y8/
Coding: 0021299
VCID: 2C530083F4CB
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 B HW: 1K0 953 549 B
Component: Lenksäulenmodul 013 0010
Coding: 0012042
VCID: 316D11F7D3E9
Part No: XXXXXXXXXXX
Component: Lenkradmodul 004 0060
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 5P0 920 822 E
Component: KOMBIINSTRUMENT VO3 1056
Coding: 0002101
Shop #: WSC 82617 264 183486
VCID: 316D11F7D3E9
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 C HW: 1K0 907 951
Component: Gateway H08 0080
Revision: 08 Serial number: 260010492202E4
Coding: 3F3F0740071202
VCID: 2759FFAFED2D
Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
Component: IMMO 1056
VCID: 316D11F7D3E9
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX1.lbl
Part No: 1T0 959 701 A
Component: Tuersteuergeraet 09 0139
Coding: 0000016
VCID: 356525E72781
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K1 909 144 G
Component: EPS_ZFLS Kl.13 1401
VCID: 2F69178FC5DD
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 BL
Component: 01 KSG 0301
Coding: 88C000BC090005054C4F863000
Shop #: WSC 80553 472 08679
VCID: 7BF1F3DF4125
Subsystem 5 - Part No: 5P0 951 171 C
Component: Innenraumueberw.009 4865
Coding: 00000000
Shop #: WSC 00000
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H02 1301
Component: NGS n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX1.lbl
Part No: 1T0 959 702 A
Coding: 0000016
VCID: 366722EB3A87
1 Fault Found:
00933 - Electric Window Motor; Passenger Side (V148)
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No: 5P1 035 152
Component: Radio BNO 0031
Coding: 0040400
VCID: E6C732ABAAA7
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN1.lbl
Part No: 1K0 959 703 B
Component: Tuersteuergeraet 06 0216
Coding: 0000016
VCID: 2F69178FC5DD
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN1.lbl
Part No: 1K0 959 704 B
Coding: 0000016
VCID: 306B14F3D8E3
Address 76: Park Assist Labels: 1K0-919-283.lbl
Part No: 5P0 919 283
Component: 06 Einparkhilfe 0101
VCID: F5E565E7E701
Address 01: DTCs cleared
Soso-CKX
Re: rog informatii
24 Dec 2012, 04:52
Pierderea de antigel nu-ti iese la diagnoza. :| trebuie sa te uiti bine pe sub capota si sa vezi unde pica. Cand lasi masina parcata mai multa vreme in acelasi loc, gasesti ceva lichide sub ea? Cat inseamna pierderea asta ca, cantitate?
La ce ai postat acolo din cate ma pricep eu la diagnoze(aproape deloc), iti arata ca ai un contact imperfect pe la calculatorul de coloana si in rest totul e fara erori din cate am observat.
cornelius
Re: rog informatii
24 Dec 2012, 21:23
Pierderea antigelului se face (la mine cel putin asa a fost), pe la o termocupla de pe radiatorul de racire a motororului.
Din cauza alternantei cald/rece a lichidului din radiator, garnitura termocuplei isi pierde etanseitatea.
Uita-te cu o lanterna la termocupla si vezi daca este umeda, mai mult ar trebui sa fie lichid si pe furntunul de retur aflat sub ea.
Seat Cordoba 2006
1.4 16V 100CP Rosu Emocion
Tel:0723.281.792
Tel:0749.546.788
olirad
Re: rog informatii
25 Dec 2012, 23:44
nu il pierd pe nicaieri , adica vizibil nu este nimic ... am completat cca 350- 400 ml dupa 500km parcursi .
intamplandu-se deja a treia oara , m-a facut sa ma gandesc ca e ceva in neregula ....
Costinel
Re: rog informatii
27 Dec 2012, 10:49
Salut, pierzi lichid pe traseu pe undeva verifica vasul si traseul vezi pe unde ai vreun T ceva, vreo imbinare. P S nu merge cu masina fara lichid, la nivel minim macar sa fie
Costinel leon 1m 1.9 tdi arl 150 hp;
Leon 5f st 2.0 tdi 150 hp
axxa84
Re: rog informatii
19 Mar 2013, 15:16
dacă e motor BKD, începe să strângi bani de schimbat chiuloasa!
vtmauto
Re: rog informatii
09 Apr 2013, 21:22
Aproape 100% sigur, daca e cod de motor BKD, axxa84 are dreptate, si sunt probleme cu chiulasa, dar mergi la un service cu elevator si uita-te foarte bine sa nu pierzi undeva pe traseu.
Daca problema e chiulasa, poti cumpara una de motor BMN (2.0TDI 170cp), neechipata, fie noua sau SH.
In cazul in care mai ai nevoie de ajutor ma poti contacta...am piese noi si SH si ma ocup de mecanica. (0733.193.500 / 0744.530.800)
OvidiuNicoara
Localitate: Turda , Judet Cluj
Re: rog informatii
09 Apr 2013, 21:48
La prima eroare zice ca ai probleme la controlerul de coloana de directie iar la a 2 a motor geam electric la partea pasagerului :tongue , cu restu sper sa te ajute colegii , nu ma pricep . :hi
viewtopic.php?f=134&t=14688 - My Car :glasses
Seat Leon - 1.6 16V - 77Kw - 2002
EX : Daewoo Matiz - 2005 .
