iulian06
Vag-com 20.4.2 hex V2
01 Sep 2020, 11:45
Just to be clear.. cable working with version from Website.. not like other sellers !
Comes with latest software 20.4.2 released this week
Cars from 1990 to 2020 September
Unlimited vins..
Using VCDS on a Windows PC, you can:
*read and clear fault codes from all systems within the car, e.g. engine, airbag, ABS, instruments, parking sensors etc.
*view live data from the sensors within the car
*reset service lights (both fixed and variable service intervals)
*read stored and intermittent fault codes
*graph and log live data with the car running
*automatically read fault codes from all car systems in a single search
*perform basic setting functions, adaptations and soft coding
*activate service functions, such as Electronic Park Brake (EPB) to allow brake pad changes
*supports bi-directional output test and component actuation
FUNCTIONS INCLUDE :
>Reset all service indicators (including 2010 and later Audi and VW)
>Read out live data of all your cars sensors
>Reads and clears all fault codes
>Covers all modules including airbag, ABS, engine, gearbox, central locking
>Retracts handbrake for pad change – Electronic parking brake systems
>Rear brake servo replacement
>ABS light reset
>Throttle body adaptions
>DPF regeneration static, driveway
>Mileage reading and correction
>ABS Bleeding
>Full long coding
>Output tests
>TDI timing Graph
>Security access
>Freeze frame data
>Electric windows
>Key coding
>Tow bar coding
Turning on LED at coming/leaving home - dependent on if you have light/rain sensors installed
Adjusting DRL LED brightness - Default is only 9%
Turning on Fog Light cornering lights
Unlock MMI hidden menu on MMI 2G and 3G
ADAPTATION SAVING (CHANGING OF LOCKING, LIGHTS AND HORN BEHAVIOUR)
Opening and closing window using car alarm remote
Activate retrofitted DRL LED lights
Automatic turn on headlights permanently
Activate door warning lights
Activate Footwell lights
Activate Underdoor lights
Activate DLR for rear lamp lights during the day.
Remove the chrome sound for seat belt
Handbrake release without seat belt
Activate rain sensors
Removing SatNav DVD factory locked -eject button to work
Activate automatic door locking over 10mph
Activate automatic door unlocking single or multi door when key removed
Activate retrofitted Sat Nav
Activate Folding door mirrors
Dial Sweep/Needle Sweep at engine start up
Changing the stereo start up logo to S-Line or RS
Activate chirping/horn (dependent on car make) when unlocking/locking car
Restart of airbag lights
Removing the Service Due error lights
Audi Passenger Door Tilt on Reverse
Activate Activating Tyre Monitoring Pressure System TPMS
Activate Battery Meter on the MMI
Activate anything which you have retrofitted yourself
On some diesel models, a forced regeneration of the DPF is possible
Pret: 400 lei
Tel: 0721590800
Ofer servicii de diagnoza auto specializata,execut lucrari de mecanica pentru toate marcile din grupul VAG (VW/Skoda/Audi/Seat)
