Buna seara, ma poate ajuta cineva cu erorile de la usi? se poate coda prin diagnoza sau trebuie demontat si vazut care e problema?(erorile au inceput dupa ce am vopsit masina complet)atasez codarea, multumesc
Thursday,21,February,2019,18:06:10:00006
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 18.2.0.3 (x64)
Data version: 20180212 DS287.0
www.Ross-Tech.com
VIN: VSSZZZ1PZ7R017636 License Plate: SEATIT
Mileage: 207470km-128915mi Repair Order:
Chassis Type: 1P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: VSSZZZ1PZ7R017636 Mileage: 207470km-128915miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: Sporadic communication error 1000
72-Door, Rear Right -- Status: Sporadic communication error 1000
Address 01: Engine Labels: 03G-906-016-BKC.clb
Part No SW: 03G 906 021 LK HW:
Component: R4 1,9L EDC G000SG 9249
Revision: --H02--- Serial number: SEZ7Z0F3547331
Coding: 0050071
Shop #: WSC 21202 136 87566
VCID: 73E569CE12B52EDC15-8026
1 Fault Found:
000564 - Boost Pressure Regulation
P0234 - 000 - Limit Exceeded (Overboost Condition)
Freeze Frame:
Fault Status: 01110000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 207414 km
Time Indication: 0
Date: 2000.00.00
Time: 20:52:02
Freeze Frame:
RPM: 2730 /min
Speed: 95.0 km/h
Load: 94.5 %
Voltage: 14.36 V
Bin. Bits: 00101000
Absolute Pres.: 2029.8 mbar
Absolute Pres.: 2560.2 mbar
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
Part No: 1K0 907 379 P
Component: ASR FRONT MK70 0105
Coding: 0000641
Shop #: WSC 06403 785 00200
VCID: 3F8DF5FE6E7DBABC21-806A
1 Fault Found:
00287 - ABS Wheel Speed Sensor; Rear Right (G44)
008 - Implausible Signal - Intermittent
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No: 5P0 820 047 K
Component: Climatic PQ35 011 0201
Shop #: WSC 00000 000 00000
VCID: 356197D65C4170ECFB-8060
No fault code found.
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 E HW: 3C0 937 049 E
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000004209747
Coding: 81880F2F00041000001D00000000000000017F075C
VCID: 2B55B1AE8A05361C9D-807E
Subsystem 1 - Part No: 1P0 955 119 A Labels: 1KX-955-119.CLB
Component: Wischer SE350 012 0403
Coding: 00056272
Shop #: WSC 06403
2 Faults Found:
01333 - Door Control Module; Rear Left (J388)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 58
Mileage: 207172 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 13.05 V
OFF
OFF
OFF
OFF
OFF
01334 - Door Control Module; Rear Right (J389)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 58
Mileage: 207172 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 13.05 V
OFF
OFF
OFF
OFF
OFF
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 L HW: 3C0 909 605 L
Component: R2 AIRBAG VW8 030 2522
Revision: 12030000 Serial number: 003B0PSFXBJG
Coding: 0021042
Shop #: WSC 81033 120 08486
VCID: 2F6DA5BEBE1D4A3CB1-807A
Subsystem 1 - Serial number: 6332MSME1100084F
Subsystem 2 - Serial number: 6342MSME10626846
Subsystem 3 - Serial number: 6351HTS6PLLI23Q2
Subsystem 4 - Serial number: 6361HTS6PLLU4NL2
Subsystem 5 - Serial number: 00000000000000000
Subsystem 6 - Serial number: 00000000000000000
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 BC HW: 1K0 953 549 BC
Component: Lenksäulenmodul 636 0070
Coding: 0000042
VCID: 74E76AD217BB29E40C-8020
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1P0 920 823 G
Component: KOMBIINSTRUMENT VO3 0422
Coding: 0002101
Shop #: WSC 00581 210 64475
VCID: 306FA6C2A32355C4A8-8064
Address 19: CAN Gateway Labels:. 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 H HW: 1K0 907 951
Component: J533__Gateway H12 0150
Revision: H12 Serial number: 31001066148C54
Coding: 3D3F034007000202
VCID: 2C57B2B28F0B312494-8078
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 58
Mileage: 207172 km
Time Indication: 0
Date: 2000.00.00
Time: 14:49:29
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 58
Mileage: 207172 km
Time Indication: 0
Date: 2000.00.00
Time: 14:49:29
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VO3 0422
Address 42: Door Elect, Driver Labels:. 1K0-959-701-MAX3.clb
Part No SW: 1T0 959 701 G HW: 1K0 959 793 M
Component: J386 TUER-SG FT 1123
Revision: 31008001 Serial number: 00000533788127
Coding: 0004272
Shop #: WSC 12336 024 394758
VCID: 3B7581EE7A65A69C0D-806E
1 Fault Found:
01044 - Control Module Incorrectly Coded
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 37
Mileage: 206950 km
Time Indication: 0
Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.077 H07 1806
VCID: 3467AAD2573B69E4CC-8060
Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0202
Revision: 00020000 Serial number: 00000000000000
Coding: 198000005283CC7F0006050560084F01207C80
VCID: 0305390E42151E5C05-8056
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
1 Fault Found:
00896 - Trunk Lock Unit (F256)
Freeze Frame:
Fault Status: 00101000
Fault Priority: 4
Fault Frequency: 1
Reset counter: 62
Mileage: 207251 km
Time Indication: 0
Date: 2000.00.00
Time: 11:21:47
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MAX3.clb
Part No SW: 1T0 959 702 G HW: 1K0 959 792 M
Component: J387 TUER-SG BT 1123
Revision: 11006001 Serial number: 00000011068606
Coding: 0000176
VCID: 3C7782F27F6BA1A404-8068
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No: 1P1 035 186 B
Component: Radio BVX 0006
Coding: 0020414
Address 62: Door, Rear Left Labels:. 1K0-959-703-GEN3.clb
Part No SW: 1K0 959 703 N HW: 1K0 959 795 H
Component: J388 TUER-SG HL 1103
Revision: 11004001 Serial number: 00000000190362
Coding: 0000144
Address 72: Door, Rear Right Labels:. 1K0-959-704-GEN3.clb
Part No SW: 1K0 959 704 N HW: 1K0 959 794 H
Component: J389 TUER-SG HR 1103
Revision: 11004001 Serial number: 00000000196621
Coding: 0000144
End-------------------------(Elapsed Time: -2:-36)-------------------------
