  • 9
  • 10
grasuraul
Localitate: Bistrita
Re: My first car, My Toledo :)
12 Noi 2017, 11:05
Inca nu e gata interiorul, mai am de lucru la el....o sa revin cu poze dupa ce finalizez :)
My Toledo 1.9 TDI
Olaru.Alexandru
Localitate: Bacau
31 Dec 2017, 08:32
La multi ani cu sanatate si tot ce este mai bun!
Toledo 1M 2002/ASV/1,9 TDI/110 CP
Olaru.Alexandru
Localitate: Bacau
18 Ian 2018, 12:53
Salutare tuturor. Vine iarna si curg problemele:((
Dupa o scanare scurta:( a urmat avalansa:
Thursday,18,January,2018,12:05:54:26365
VCDS Version: Release 805.0
Data version: 20080529
Chassis Type: 1M - Seat Leon/Toledo
Scan: 01 02 03 08 15 17 19 22 35 36 37 46 56
VIN: VSSZZZ1MZ2B003638 Mileage: 218420km/135719miles
Part No: 038 906 012 FK
Component: 1,9l R4 EDC 0420SG 3357
Coding: 00002
Shop #: WSC 00046
VSSZZZ1MZ2B003638 SEZ7Z0A1200224
No fault code found.
Readiness: N/A
Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-F.lbl
Part No: 1C0 907 379 E
Component: ESP FRONT MK60 0104
Coding: 0019458
Shop #: WSC 00046 615 1234567
1 Fault Found:
01435 - Brake Pressure Sensor 1 (G201)
008 - Implausible Signal
Address 08: Auto HVAC Labels: 1M0-820-043.lbl
Part No: 1M0 820 043 E
Component: 1M-CLIMATRONIC X0702
Coding: 00044
Shop #: WSC 06402
Part No: 1C0 909 605 A
Component: 1L AIRBAG VW51 0A 01
Coding: 12620
Shop #: WSC 00046
3 Faults Found:
01217 - Side Airbag Igniter; Driver Side (N199)
32-10 - Resistance too High - Intermittent
01218 - Side Airbag Igniter; Passenger Side (N200)
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 17: Instruments Labels: Redir Fail!
Part No: 1M0 920 822 D
Component: KOMBI+WEGFAHRSP VDO V01
Coding: 05122
Shop #: WSC 31414
3 Faults Found:
01039 - Coolant Temperature Sensor (G2)
30-10 - Open or Short to Plus - Intermittent
00779 - Outside Air Temp Sensor (G17)
29-10 - Short to Ground - Intermittent
Address 19: CAN Gateway Labels: 6N0-909-901.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 00046
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 F
Component: 93 Komfortgerát HLO 0003
Coding: 00259
Shop #: WSC 00046
Part No: 1C0959801B
Component: 3K Tõrsteuer.FS KLO 0001
Part No: 1C0959802C
Component: 3K Tõrsteuer.BF KLO 0002
Part No: 1C0959811A
Component: 3K Tõrsteuer.HL KLO 0002
Part No: 1C0959812A
Component: 3K Tõrsteuer.HR KLO 0002
1 Fault Found:
01336 - Data Bus for Comfort System
80-10 - Single-Wire Operation - Intermittent
Am un scurt circuit la mansonul acela de la portbagaj care duce spre tripla. Este posibil ca de la el sa am toate aceste erori, sau poate sa fie de la contacte imperfecte la baterie.
Nu as vrea si sper ca nu senzorii sunt de vina si sa trebuiasca inlocuirea lor:(
Daca ma poate indruma careva, va apreciez, si multumesc mult.
O zi buna.
18 Ian 2018, 13:44
Mai ai un fir de CAN rupt undeva la usi, tot in mansoane. Senzorul de temperatura motor (partea de indicatie) e cu probleme, trebuie schimbata sonda G2/G62. La airbaguri...banuiesc ca ai pus contactul cand lucrai la scaune. Ai umblat la bara fata in ultima vreme?
Olaru.Alexandru
Localitate: Bacau
18 Ian 2018, 14:09
Nu am umblat la nimic in fata doar la camera aia de marsarier. Masina a ramas afara in ultima vreme. In rest nimic.
Multumesc pentru sprijin.
18 Ian 2018, 18:04
In mansonul cu fire de la portbagaj nu ai fire de CAN. Ai doar fire pentru becuri si motorasul portbagajului. La airbaguri ar fi prea mare ghinionul sa ai probleme cu mufele la amandoua scaunele in acelasi timp. La instrumente ai senzorul G2 defect si cel din bara posibil cu probleme la fire, de aia am intrebat daca ai umblat la bara. La ABS acel senzor e in pompa, nu stiu ce sa-ti zic de el. Sterge eroarea si urmareste cateva zile in prima faza.
Olaru.Alexandru
Localitate: Bacau
18 Ian 2018, 21:06
Multumesc maestre. La portbagaj am scurt intre pozitii-ceata- si becul de la portbagaj. Trebuie sa desfac mansonul si sa repar ce e pe acolo. Apoi vad cum sigilez mansonul la loc. Dupa asta am sa vad cu restul.
O seara buna
18 Ian 2018, 21:58
Scoti cablul de unde ajunge langa lampa din stanga, scoti cablajul cu tot cu tub de cauciuc, ungi cu ceva firele si tragi de tub spre zona unsa. Repari firele, izolezi, ungi si tragi tubul inapoi. Simplu.
grasuraul
18 Ian 2018, 22:52
Aceeasi problema am avut si eu la firele ce merg pe usa de la portbagaj, s-au forfecat in tubul de cauciuc de la uzura...le-am tras afara si le-am inlocuit cu altele , continuitatea (lipiturile) le-am facut in portbagaj si in usa portbagajului . De atunci totul e ok. Munca de una dupa-masa :)
My Toledo 1.9 TDI
Olaru.Alexandru
Localitate: Bacau
19 Ian 2018, 07:03
Saru'mana la voi. O zi usoara si multa sanatate
Olaru.Alexandru
Localitate: Bacau
25 Ian 2018, 21:54
Quick update. Cablaj rezolvat la portbagaj. 2 fire rupte( masa si frana) si 5 cu izolatia crapata. Am inlocuit cele 2 si izolat cele 5. Sper sa mai tina un pic:)
Urmeaza senzorul de la pompa de frana. Oare din cauza lui nu se mai aprinde frana?
O seara buna
26 Ian 2018, 08:08
Nu, din cauza switchului de la pedala.
Undertacher
26 Ian 2018, 08:36
Ce senzor este la pompa de frana?
26 Ian 2018, 14:29
Alex, mai intai schimba switchul pedalei de frana. Apoi vezi daca mai apare faultul cu senzorul din pompa de frana. Asta dupa ce il stergi initial.
Olaru.Alexandru
Localitate: Bacau
26 Ian 2018, 16:37
ok, multumesc.
  • 9
  • 10
