criste
Temponatul nu functioneaza
17 Mar 2024, 15:16
Salutare,
Am montat maneta cu tempomat pe masina, dar nu functioneaza.
Masina: Seat Leon 1P 2008, 1.4 16v BXW
Cod maneta montata OE: 1K0 953 513G
Pe motor/engime imi acepta codul 11463
dar pe 16 Steering - cand schimb penultima cifra imi da "code rejected".
La scanare primesc aceasta eroare:
1 Fault Found:
28776 - No Communication with Cruise Control Module
U0104 - 000 -
Freeze Frame:
Fault Status: 01110000
Fault Priority: 1
Fault Frequency: 1
Reset counter: 39
Mileage: 68106 km
Time Indication: 0
Date: 2000.01.01
Time: 21:18:25
Serie ceasuri:
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1P0 920 807 KX
Component: KOMBIINSTRUMENT VO3 0952
Coding: 0002101
Shop #: WSC 80093 222 69422
VCID: 0E131B3F19576CE349-805A
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 BM HW: 1K0 953 549 BM
Component: J0527 752 0101
Coding: 0000002
Shop #: WSC 06402 785 00200
VCID: 7EF34BFF29F77C63B9-802A
Address 01: Engine Labels: 03C-906-024-BXW.lbl
Part No SW: 03C 906 024 BC HW: 03C 906 024 AS
Component: MARELLI 4HV G 2149
Revision: --H06--- Serial number: SEX7Z0H331B04T
Coding: 0004071
VCID: 60CF1587B343AA93AB-8034
VINID: 9A38EAAAA060A88881008048203816AE1F
Multumesc anticipat!
Re: Temponatul nu functioneaza
19 Mar 2024, 14:02
Nu e compatibila electronica de coloana de directie.
BM e lowline, nu suporta nici o functie. E nevoie de minim BN (medium) sau BP / BS (highline, astea suporta pe langa cruise si BC si comenzi pe volan)
criste
21 Mar 2024, 20:57
Am cumparat un alt calculator de coloana, l-am codat la fel ca pe cel vechi,
"Coding accepted"
dar problema este ca s-a activat claxonul, masina claxoneaza continuu cand pun contactul si nu stiu cum sa-l opresc/dezactivez.
Calculator Coloana -cumparat SW: 1K0 953 549 CB
Calculator Coloana - Original/Stock
Asa ca am montat inapoi claculatorul masinii si problema cu claxonul a disparut.
Acum nu stiu care sa fie cauza.
criste
27 Mar 2024, 16:22
Revin cu rezolvarea problemei.
Am comandat un alt calculator de coloana, de aceasta data acesta a fost compatibil cu masina.
CalcColoana 1K0-953_549-BN
Primul modul nu stiu ce problema a avut, dar nu a functionat.
1. L-am montat,
2. L-am codat la fel ca cel de pe masina.
3. Am adugat optiunea de Cruise Control in Modulul 16 si apoi in Modulul 01 Engine.
4. Am calibrat G85
Sensor for Steering Angle (G85)
Prerequisites:
Start the vehicle.
Turn the steering wheel one turn to the right and one turn to the left.
Drive in a short distance straight line on a level surface at a speed not higher than 20 km/h.
If the steering wheel is straight during the test drive then stop the vehicle with the wheels pointed straight.
Ensure that the steering wheel is not moved again.
Keep the engine running and do not switch off the ignition.
System voltage at least 12.0 V.
[Select]
[44 - Steering Assist]
[Coding-II - 11] or if that function is not available then use [Sec.Access - 16] instead
Enter 40168, to enable the basic setting.
[Do it!]
[Basic Settings - 04]
Group 060
[Go!]
Activate the Basic Setting.
[ON/OFF/Next]
After a successful basic setting, field 1 should say "OK".
[Done, Go Back]
To make sure the basic setting was successful, check the sensor again.
[Measuring Blocks - 08]
Group 007
[Go!]
Check field 1, the value has to be between -1.5 and +1.5 °.
[Done, Go Back]
[Close Controller, Go Back - 06]
Note: After successful basic setting, the Steering Limit Stop needs to be adapted too.
5. A facut adaptarea Steering Limit Stop
(Engine still running)
Center steering wheel (±10°) and hold it centered for 5 seconds.
Turn steering wheel completely to the left and hold it there for 10 seconds.
Turn steering wheel completely to the right and hold it there for 10 seconds.
Center steering wheel (±10°).
Switch OFF engine and ignition.
Switch ON ignition.
Wait 5 seconds.
Steering Assist Warning Lamp should turn OFF. If it doesn't, perform a short test drive.
Tempomatul este functional si se aprinde si martor in bord cand este activat.
CalcColoana_1K0-953_549-BN compatibil
CalcColoana-Stock
