rog informatii
Scris: 09 Dec 2012, 17:07
salut ,
am o problema , poate ma ajuta cineva .
am un SEAT TOLEDO 2005 , 1968tdi , dispare antigelul constant de cateva luni , fara a avea alte simptome
am facut un test , daca ma poate ajuta cineva cu citirea lui ...
Tuesday,01,March,2011,14:42:07:10074
VCDS Version: Beta 11.2.0 (x64)
Data version: 20110207
Chassis Type: 1K0
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 76
VIN: VSSZZZ5PZ5R054193 Mileage: 125030km/77690miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 016 HM HW: 028 101 195 0
Component: R4 2,0L EDC G000AG 7000
Revision: 12345678 Serial number: SEZ7Z0D2781374
Coding: 0050078
Shop #: WSC 80553 264 08679
VCID: 75E5E5E76701
1 Fault Found:
18104 - Powertrain Data Bus: Implausible Message from Steering Column Controller
P1696 - 000 - - - Intermittent
Freeze Frame:
RPM: 0 /min
Torque: 56.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.39 V
Bin. Bits: 00101100
Bin. Bits: 11000000
(no units): 4.0
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 041 HW: 02E 927 770 AD
Component: GSG DSG 041 0814
Revision: 03904010 Serial number: 00000410160148
Coding: 0000020
Shop #: WSC 06402 785 00200
VCID: CFA9F70F251D
No fault code found.
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0104
Coding: 0023282
VCID: 3A7F36DB0E9F
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 5P0 907 044 B
Component: ClimatronicPQ35 005 0202
Shop #: WSC 00000 000 00000
VCID: 2F69178FC5DD
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 1K0 937 049 N HW: 1K0 937 049 N*
Component: Bordnetz-SG H34 0803
Revision: 00H34000 Serial number: 00000001333573
Coding: 81880F2700041000001E00000100000000007F0B5C
VCID: 3A7F36DB0E9F
Subsystem 1 - Part No: 5P0 955 119 A
Component: Wischer SE359 012 0402
Coding: 00056272
Shop #: WSC 80553
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 C HW: 1K0 909 605 C
Component: S3 AIRBAG VW8 013 2100
Revision: 02013000 Serial number: 0033HD014Y8/
Coding: 0021299
VCID: 2C530083F4CB
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 B HW: 1K0 953 549 B
Component: Lenksäulenmodul 013 0010
Coding: 0012042
VCID: 316D11F7D3E9
Part No: XXXXXXXXXXX
Component: Lenkradmodul 004 0060
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 5P0 920 822 E
Component: KOMBIINSTRUMENT VO3 1056
Coding: 0002101
Shop #: WSC 82617 264 183486
VCID: 316D11F7D3E9
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 C HW: 1K0 907 951
Component: Gateway H08 0080
Revision: 08 Serial number: 260010492202E4
Coding: 3F3F0740071202
VCID: 2759FFAFED2D
Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
Component: IMMO 1056
VCID: 316D11F7D3E9
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX1.lbl
Part No: 1T0 959 701 A
Component: Tuersteuergeraet 09 0139
Coding: 0000016
VCID: 356525E72781
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K1 909 144 G
Component: EPS_ZFLS Kl.13 1401
VCID: 2F69178FC5DD
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 BL
Component: 01 KSG 0301
Coding: 88C000BC090005054C4F863000
Shop #: WSC 80553 472 08679
VCID: 7BF1F3DF4125
Subsystem 5 - Part No: 5P0 951 171 C
Component: Innenraumueberw.009 4865
Coding: 00000000
Shop #: WSC 00000
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H02 1301
Component: NGS n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX1.lbl
Part No: 1T0 959 702 A
Coding: 0000016
VCID: 366722EB3A87
1 Fault Found:
00933 - Electric Window Motor; Passenger Side (V148)
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No: 5P1 035 152
Component: Radio BNO 0031
Coding: 0040400
VCID: E6C732ABAAA7
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN1.lbl
Part No: 1K0 959 703 B
Component: Tuersteuergeraet 06 0216
Coding: 0000016
VCID: 2F69178FC5DD
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN1.lbl
Part No: 1K0 959 704 B
Coding: 0000016
VCID: 306B14F3D8E3
Address 76: Park Assist Labels: 1K0-919-283.lbl
Part No: 5P0 919 283
Component: 06 Einparkhilfe 0101
VCID: F5E565E7E701
End ---------------------------------------------------------------------
Address 01: DTCs cleared
Chassis Type: 1K0
Coding: 0050078
VCID: 75E5E5E76701
1 Fault Found:
Freeze Frame:
RPM: 0 /min
Torque: 56.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.39 V
Bin. Bits: 00101100
Bin. Bits: 11000000
(no units): 4.0
Coding: 0000020
VCID: CFA9F70F251D
Coding: 0023282
VCID: 3A7F36DB0E9F
VCID: 2F69178FC5DD
VCID: 3A7F36DB0E9F
Coding: 00056272
Shop #: WSC 80553
Coding: 0021299
VCID: 2C530083F4CB
Coding: 0012042
VCID: 316D11F7D3E9
Coding: 0002101
VCID: 316D11F7D3E9
VCID: 2759FFAFED2D
VCID: 316D11F7D3E9
Coding: 0000016
VCID: 356525E72781
VCID: 2F69178FC5DD
VCID: 7BF1F3DF4125
Coding: 00000000
Shop #: WSC 00000
Coding: 0000016
VCID: 366722EB3A87
1 Fault Found:
Coding: 0040400
VCID: E6C732ABAAA7
Coding: 0000016
VCID: 2F69178FC5DD
Coding: 0000016
VCID: 306B14F3D8E3
VCID: F5E565E7E701
