Salut baieti revin cu o noua problema la leon-ul meu. Aseara mergeam pe strada si mi-a murit masina in mers, am tras pe dreapta, am tractat pana acasa si am scanat cu vcds. Pun mai jos de am primit in urma scaului. Precizez ca dupa ce am sters erorile masina a pornit, dar variaza la relanti de parca as calca pedala de acceleratie acul urca in sus si in jos si se aude si motorul cum se accelereaza si decelereaza. Aveti cumva vreo idee sa fie cablurile ,conectica sau ... parca sunt prea multi senzori care sa pice din senin.
Address 01: Engine Labels: Redir Fail!
Part No: 036 906 034 CP
Component: MARELLI 4MV 4376
Coding: 00031
Shop #: WSC 88801
VCID: 62C01DE2EE98A708571
VSSZZZ1MZ2R084636 SEZ7Z0A1485825
3 Faults Found
16786 - EGR System
P0402 - 35-00 - Excessive Flow
17563 - Manifold Pressure Sensor (G71)
P1155 - 35-10 - Short to Plus - Intermittent
16705 - Engine Speed Sensor (G28)
P0321 - 35-10 - Implausible Signal - Intermittent
Readiness: 0010 0101
Address 03: ABS Brakes Labels: 1C0-907-37x-ABS.lbl
Part No: 1C0 907 379 J
Component: ABS FRONT MK60 0103
Coding: 0001025
Shop #: WSC 00001 001 00001
VCID: 3162A2AEABFE4C909EB
2 Faults Found
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
004 - No Signal/Communication - Intermittent
Address 17: Instruments Labels: 1M0-920-xx2-17.lbl
Part No: 1M0 920 802 A
Component: KOMBI+WEGFAHRSP VDO V03
Coding: 04106
Shop #: WSC 00000
VCID: 244C5BFAB40CE93865D
1 Fault Found
49-10 - No Communications - Intermittent
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 06441
VCID: F0E4E7AAB0748598515
1 Fault Found
